FXS busy problem.
Nov 17th, 2009
I have a scenario with a fax printer (Konica Minolta c353) connected to one interface VIC3-2FXS/DID (just one of the fxs ports), the calls are forward to VWIC2-1MFT-T1/E1 interface with MGCPAPP (registered in CUCM7.02).
Most of the times we need to reboot the router because the fax line stays busy for long periods of time, and this workaround does not work every time.
What can be the problema here???
Router INFO:
PID: CISCO2811
PID: VWIC2-1MFT-T1/E1
PID: VIC3-2FXS/DID
PID: PVDM2-32
PID: PVDM2-16
IOS: (C2800NM-IPVOICEK9-M), Version 12.4(15)XZ2
ROUTER RUNNING CONFIG:
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:15
cptone PT
voice-port 0/1/0
cptone PT
voice-port 0/1/1
cptone PT
ccm-manager redundant-host 10.88.11.1 10.88.21.1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.88.31.1 10.88.11.1 10.88.21.1
ccm-manager config
mgcp
mgcp call-agent 10.88.31.1 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
Best Regards,
Nuno
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
paolo bevilacqua Tue, 11/17/2009 - 09:05
  • Hall of Fame,
    Founding Member
Try updating IOS, eg 12.4(22)YB4
nunoscosta Tue, 11/17/2009 - 09:11
I have another scenario with different fax printer on another location, the router have the same characteristcs.
Are you sure the IOS is the problem here?
Thanks in advance.
