SA520W Vlan's & DHCP and wireless LAN
Nov 16th, 2009
Hi just started to configure my new firewall and ran into some problems:
1     I setup 3 VLAN's but cannot assign different subnets trough DHCP or manually.
       VLAN 's are working fine but they all get an ip from the same DHCP pool.
2    I setup one WLAN for each VLAN but there is no option to assign an SSID to a VLAN.
      No WLAN can access the LAN, can that be done?
Thank you.
robertfeenstra Wed, 11/18/2009 - 08:03
Just got my question answered by a SBSC Nework Engineer (Richard):
The SA520 only has one DHCP scope, as you mentioned.   As a result, the
VLAN's are all port based VLAN's.
The steps you want to take to add your wireless SSID's to your vlan's is as follows:
1)   Under Wireless - Profiles - Create your SSID's.
2)   Under  Networking -  VLAN - Port VLAN  - You should see your
wireless SSID's listed here under your wired VLAN's.
3)    Under Port VLAN,  Select the SSID that you want to add to VLAN's
and select EDIT.   -   Add VLAN's to that SSID.   In order to select
multiple VLAN's for a given SSID, you must set it to either General or Trunk port.
Tested by me and it works perfect.
Related Content
