Can WAP200E repeat with other AP models?
Answered Question
Nov 17th, 2009
Hi guys,
Can WAP200E repeat with other AP models? I think it should be working with other models as the signal should be the same in different APs. Is that correct ?
Henry
Correct Answer by jestowe about 7 years 4 months ago
Sir,
Thank you for visiting Cisco Community Forum.
Note: For the AP Client and Wireless Bridge Modes, the remote access point must be a second Linksys Wireless-G Access Point. For the Wireless Repeater mode, the remote wireless bridge must be a second Linksys Wireless-G Access Point or Wireless-G Router.
The WAP200E uses WDS (http://en.wikipedia.org/wiki/Wireless_Distribution_System) - WDS may be incompatible between different products (even occasionally from the same vendor) as it is not certified by the Wi-Fi Alliance
http://www.cisco.com/en/US/products/ps10047/products_qanda_item09186a0080a38f1f.shtml
It may be possible to bridge different models if they also use WDS where you can match up the MAC addresses on both sides.
Jeff.
Overall Rating: 5 (1 ratings)
Correct Answer
jestowe Tue, 11/17/2009 - 18:30
Sir,
Jeff.
