SPA8800 Template / Line ID's help.
Nov 18th, 2009
Hi there,
I'm trying to set up the Template for the SPA8800 xml correctly but i'm failing a a certain point.
Inside the XML there are a total of 8 Profiles for Lines / Phones.
The only problem is that 7 of them are for the Phone Configuration which i dont really need and only 1 of them are for configuring only ONE of the lines.
What i basically want to do is to have a template so that will have all 4 Line's in it and not only 1.
Did i miss something / doing something wrong?
I already exported the XML from the Spa8800 and using it  to provision the first line works, but i cant seem to get the other lines to work.
3cxcisco08 Wed, 11/18/2009 - 01:41
Nevermind,
After a couple of days of Headbashing i found out that the template was fine, just a bit confusing.
Phone 1 = Proxy1
Phone 2 = Proxy3
Phone 3 = Proxy5
Phone 4 = Proxy7
Line 1 = Proxy2
Line 2 = Proxy4
Line 3 = Proxy6
Line 4 = Proxy8
Supermathie Wed, 10/05/2011 - 14:05
Do you happen to remember how you exported the XML configuration from the SPA8800?
That's the problem I'm trying to solve.
Thanks!
