PVC 300 can support RTSP on IPv6 using 3GPP
Answered Question
Nov 18th, 2009
Hello team Our customer asks us to do video surveillance test for their network.It must support RTSP on IPv6 network using 3GPP outbound interface.Our CIVS-IPC 2500/4500 will support IPv6 fully including software until 2012 (based on roadmap documents)Do you think Cisco Small Business PVC300 Pan Tilt Optical Zoom Internet Camera can do it not familiar with this product?
I know usually under ipv4 enviroment, this camera will support RTSP and 3GPP outbound. But is it same on IPv6 network enviroment?
Thank you so much
Kindest Regards
Correct Answer by Steven DiStefano about 7 years 7 months ago
You are correct that the PVC300 supports RTSP 3GPP access and I have done this with IPV4.
The camera does offer IPV6, but I havent tried it (hard to see but if you click it should get bigger; notice IPV6 enable at the bottom...
Overall Rating: 5 (1 ratings)
Correct Answer
Steven DiStefano Thu, 11/19/2009 - 05:42
  • Blue, 1500 points or more
doku Thu, 11/19/2009 - 22:42
Steve
Thank you so much for your comment
Do other guys have any experience to use PVC300 on IPv6 network?
Kindest regards
Donghyun
Steven DiStefano Fri, 11/20/2009 - 04:58
I will ask inside on the test team now for you.
