UC540 Wizard Custom VLAN
Steven DiStefano Thu, 11/19/2009 - 05:16
  • Blue, 1500 points or more
In C:\Program Files\Cisco Systems\CiscoSMB\Cisco Configuration Assistant will be an application log.
See if you can parse that to see what you set userID to.  It is case sensitive.
I did run into an issue when I had multiple elements in the CCA topology, setting the password in TSW (Admin User is required and it doesnt allow cisco/cisco (PW size minimum too), the CCA will challenge me exactly 3 times before it lets me in the GUI.  So this may confuse someone into entering different combination (like I always have 3-4 PWs I use) and then you never get in.
Try opening a telnet or SSH session into the UC540 with the user/pass you know you entered in TSW.
We will go from there.....
Sound OK?
Steven DiStefano Thu, 11/19/2009 - 05:44
Happy to help you.  Thanks for all your posts.  Your collabortation helps us all.  You also have the answers many times and we expecially appreciate when you help us too :-)
Steve D
