Dial-peer configuration for an E-1 in Mexico
Nov 19th, 2009
Need help with dial-peers for inbound and outbound dialing with an E-1 in Mexico.
Not sure if direct-inward-dial will work or if it is needed.
Here is the config:
controller E1 0/0/1
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country telmex
  category 2
  answer-signal group-b 1
dial-peer voice 101 pots
description Local Calling Dial Peer
destination-pattern 9[2-9].......
port 0/0/1:0
forward-digits 8
dial-peer voice 102 pots
corlist outgoing LongDistance
description Long Distances Dial Peer
destination-pattern 901..........
port 0/0/1:0
forward-digits 12
gogasca Thu, 11/19/2009 - 22:44
You have a CUCM, ?
I recommend you an incoming dial-peer to configuring DID (direct inward dial) otherwise you will get dialtone and call wont be routed directly to remote station
from POTS to VoIP
then another incoming Dial-peer from VOIP to POTS (to control codec)
