GRE tunnel over ipsec with ospf Issues
Nov 19th, 2009
With reference to attached document,I want to add LAN on boh sides of the router and want to pass ospf routes via GRE Tunnel and LAN traffic via ipsec tunnel beween ASA.
What changes are required at routers and ASAs.
Thanks in advance.
seekhpar121 Thu, 11/19/2009 - 20:46
Sorry forgot to mention that Both ASA are connected via WAN Link not with the internet,
Plz reply as soon as possible.
i shall be thankful for an early reply.
jgadbois Sat, 11/21/2009 - 10:00
You might want to look at Doc ID: 63882.  I'm using this to
do a failover using a T1 and the Internet.  So
far it works just great except it won't scale past one connection.
My setup is an ASA VPNed to another
via the Internet with routers behind them with T1s.
Hope this helps.
