Problem with ip policy route-map on catalyst 3560
Nov 19th, 2009
Hello all.
Please help my.
Dont save ip policy route-map.
IOS on catalyst 3650 is c3560-ipservicesk9-mz.122-52.SE.bin
Switch(config)#route-map test-access permit 10
Switch(config-route-map)#match ip route-source 20
Switch(config-route-map)#set ip default next-hop
Switch(config)#access-list 20 permit
Switch(config)#interface vlan503
Switch(config-if)#ip policy route-map test-access
Switch(config-if)#ip route-cache policy
Switch(config)#ip local policy route-map test-access
Switch#show route-map test-access
route-map test-access, permit, sequence 10
  Match clauses:
    ip route-source (access-lists): 20
  Set clauses:
    ip default next-hop
  Policy routing matches: 384 packets, 95266 bytes
Switch#show ip policy
Interface      Route map
local          test-access
I`m dont visible string "ip policy route-map test-access" after running show running-config
interface Vlan503
ip address
ip policy route-map test-access dont setting.
Please help my.
Jon Marshall Thu, 11/19/2009 - 22:06
Have you enabled the routing template ie.
3560(config)# sdm prefer routing
