Issue in Tunnel re-establishment
Nov 19th, 2009
I successfully establised the IPsec between 2 end points which consistes of ASA followed by a router on both ends. Then i configured the GRE Tunnel between 2 end and configured OSPF. No problem in OSPF Neighbour formation. But, couple of issues
  1. When the Router reloads then the GRE is not establishing unless i execute the "clear xlate" on the ASA. when i clear the tunnel everything is working fine. Tunnel is back to normal
  2. Inorder to overcome the above issue I change the default tunnel mode to "tunnel mode ipip". The tunnel is reestablishing automatically when the router reloads and i dont have to clear the tunnel. But the OSPF is not working when "tunnel mode ipip" is used.
What could be the reason for this
Logesh
Giuseppe Larosa Fri, 11/20/2009 - 10:18
Hello Logesh,
you may want to post this in security -> firewall forum.
OSPF over GRE tunnel works, I never heard of OSPF over that other tunnel mode.
You should look for a solution that allows you to use GRE tunnel between routers.
Hope to help
Giuseppe
