CUBE sip trunk early media problem
Luk Nicolaers
We have the following setup...
Service provider sip trunk to CUBE, CUBE SIP trunk to CUCM713 and CUCM713 SIP trunk to IVR system.
We want to do early media on ringing (180).
The problem is that when the CUBE receives a ringing (180) with SDP for early media the CUBE translates this into session progress(183) with SDP This is a problem for some phones on the Service provider side...
The only way to have an incoming ringing(180) to an outgoing ringing (180) is to disable the SDP on the incoming ringing (in the CUCM trunk's SIP profile)
or to set the CUBE with: sip-ua disable-early-media 180.  This means we cannot do early media on ringing!
Is anyone having an idea why CUBE is not transparently sending in incoming ringing(180) with SDP to an outgoing ringing(180) with SDP?
Thanks for the input
Rgs,
Luk
0gbalogh
Hello!
     It seems to be, that we run to the similar problem. Is there somebody who could answer the question:
Why CUBE is not transparently sending in incoming ringing(180) with SDP to an outgoing ringing(180) with SDP?
Thanx!
Gabriel Balogh
abdel-moniem
Level 5
Level 5
Did you able to resolve this Problem ?
friskopart
did any one find the solution for this problem ? there are many discussions already for the same problem with no answer . does cisco have a solution to this ?
