Rajesh Revuru Fri, 11/20/2009 - 01:07
Have you checked under service parameters if the parameter "CDR Log calls with Zero Duration Flag" is set true? If so you may want to change it to false
Gautam Chatterjee Fri, 11/20/2009 - 03:20
there are calls getting generated with zero call duration and 0.0.0.0 ip address. this is some huge records generated every sec. do anyone know abt any bug which can cause this?
thanks in advance.
