HSRP state change
Answered Question
Nov 20th, 2009
I've got two routers: a 2821 with an interface GigabitEthernet (Active) and a 2620 with an interface FastEthernet (Standby) normally performing in a HSRP mode:
interface GigabitEthernet0/1
description LAN XXXX
ip address xxx.xxx.xx.x 255.255.255.0
no ip redirects
no ip proxy-arp
duplex full
speed 1000
standby 1 ip xxx.xxx.xx.x
standby 1 timers msec 100 msec 300
standby 1 preempt
standby 1 authentication xxxx
standby 1 track 1 decrement 50
interface FastEthernet0/0
no ip redirects
no ip proxy-arp
speed 100
full-duplex
no cdp enable
standby 1 priority 95
standby 1 preempt
In log on standby router, i can see the following message:
.Nov 20 09:21:37.398 CET: %HSRP-5-STATECHANGE: FastEthernet0/0 Grp 1 state Standby -> Active
.Nov 20 09:21:37.474 CET: %HSRP-5-STATECHANGE: FastEthernet0/0 Grp 1 state Active -> Speak
.Nov 20 09:40:38.154 CET: %HSRP-5-STATECHANGE: FastEthernet0/0 Grp 1 state Standby -> Active
.Nov 20 09:40:47.114 CET: %HSRP-5-STATECHANGE: FastEthernet0/0 Grp 1 state Active -> Speak
How can I keep from coming back? I force the port of switch to full duplex speed 100 and change the wire. Someone can help me?
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Juan,
Dec  2 14:43:52.178 CET: HSRP: Fa0/0 Grp 1 Speak: d/Standby timer expired (unknown)
this message says that the local node the C2620 is not receiving the HSRP hellos from the other router.
if the serial interface would be flapping we would see messages coming from other node with a changing HSRP priority (100 then 50 then again 100)  over time caused by the tracking.
But here it looks like a different behaviour.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 11/20/2009 - 02:32
  • Hall of Fame,
    Founding Member
Hello Juan,
try to use less aggressive timers:
use 300 and 900 msec
other users have reported problems with low timers settings
Hope to help
Giuseppe
emilio1973 Fri, 11/20/2009 - 05:30
Hello Giuseppe,
I will try it and I mention the results.
Thanks a lot.
emilio1973 Tue, 12/01/2009 - 23:23
Hi, I apologize for the delay in replying but i was on holiday. Change the timers but the message still appears very often. I need to solve this problem as soon as possible.
Giuseppe Larosa Wed, 12/02/2009 - 02:15
  • Hall of Fame,
    Founding Member
Hello Juan,
in this case I would look at spanning-tree there can be issues with STP if even with higher timers you still see these messages
Hope to help
Giuseppe
emilio1973 Wed, 12/02/2009 - 04:34
Hi Giuseppe, thanks for your help.
I spoke with the customer to know the configuration of LAN switches and there is not STP configuration. I have also asked to change the port and check the wire.
I'll keep you informed
Jon Marshall Wed, 12/02/2009 - 04:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
In addition to Giuseppe and Glen's suggestions -
you are tracking an interface on your 2821 router. Can you check that this interface is okay and is not flapping.
Jon
emilio1973 Wed, 12/02/2009 - 04:49
Hi jon, thank fo your help. These are the statistics of interface LAN of 2821 router.
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 001c.f687.8199 (bia 001c.f687.8199)
  Description: LAN IPSA
  Internet address is 213.190.6.175/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/14/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 844000 bits/sec, 427 packets/sec
  5 minute output rate 2544000 bits/sec, 414 packets/sec
     368945694 packets input, 2138214808 bytes, 0 no buffer
     Received 39632109 broadcasts, 0 runts, 0 giants, 1 throttles
     1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
     0 watchdog, 0 multicast, 0 pause input
     433755824 packets output, 1888548680 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     6266993 unknown protocol drops
     0 lost carrier, 0 no carrier, 2 pause output
Giuseppe Larosa Wed, 12/02/2009 - 04:52
  • Hall of Fame,
    Founding Member
Hello Juan,
I would try to understand if this means that STP is running with default settings or if it is not running at all it makes some difference!
your interface statistics look like correct with no meaningful errors but this doesn't mean that errors shouldn't be on switch ports, as Glen has noted you have hardcoded speed and duplex so you need to verify settings on switch ports, be aware that FE ports default to 100 Mbps half duplex.
Edit:
I see that you have already coded speed and duplex also on switch side.
just as a try. with default HSRP timers what happens? I wonder if C2620 IOS image can be a little old for this job.
Hope to help
Giuseppe
emilio1973 Wed, 12/02/2009 - 08:02
Hi Giuseppe, the IOS version is 12.3 (22). I also think it's an older version for this work but do not know what would be appropriate and how to find it. I appreciate any help
thanks
Correct Answer
Giuseppe Larosa Wed, 12/02/2009 - 12:33
  • Hall of Fame,
    Founding Member
Hello Juan,
Hope to help
Giuseppe
emilio1973 Fri, 12/04/2009 - 01:53
Hi Giuseppe, finally we decided a change although the current IOS router hardware supports (64/32) but can not think of another solution.
Thanks for your help
Emilio
glen.grant Wed, 12/02/2009 - 04:19
  • Purple, 4500 points or more
  I am assuming there is a switch between these interfaces . Check the switch interfaces for speed and duplex .  They must match whats on the routers . Seeing that they are hardcoded speeds on the routers you must hardcode the speeds on the switch also otherwise you'll have speed/duplex mismatches which causes errors and slow responses which could cause what you are seeing... check for errors on the attached switch.
emilio1973 Wed, 12/02/2009 - 04:57
Hi glen , thanks for your help. I spoke with the customer to know the configuration of ports switch and there are not speed/duplex mismatches.I have also asked me to send the statistics of switch ports.
emilio1973 Wed, 12/02/2009 - 06:50
This is a debug HSRP on backup router:
backup-router#debug standby events
HSRP Events debugging is on
backup-router#Received disconnect from xxx.xxx.xx.xxx: Time-out activated
The ip xxx.xxx.xx.xxx is the ip address of serial interface on this router (backup).
I think that the problem is on serial interfaces but the statistics looks right.
backup-router#sh int s0/0:0
Serial0/0:0 is up, line protocol is up
  Hardware is PowerQUICC Serial
  Description: E1 interface
  Internet address is xxx.xxx.xx.xxx/30
  MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP, loopback not set
  Restart-Delay is 0 secs
  Last clearing of "show interface" counters 1w1d
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 281
  30 second input rate 1000 bits/sec, 2 packets/sec
  30 second output rate 1000 bits/sec, 2 packets/sec
     179882 packets input, 5662256 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     2 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored, 0 abort
     4352950 packets output, 241052492 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     1 carrier transitions
  Timeslot(s) Used:1-31, SCC: 1, Transmitter delay is 0 flags
emilio1973 Wed, 12/02/2009 - 07:03
This is a show log on backup router:
.Dec  2 14:43:50.950 CET: %HSRP-5-STATECHANGE: FastEthernet0/0 Grp 1 state Standby -> Active
.Dec  2 14:43:50.950 CET: HSRP: Fa0/0 Grp 1 Redundancy "hsrp-Fa0/0-1" state Standby -> Active
.Dec  2 14:43:50.974 CET: HSRP: Fa0/0 Grp 1 Hello  in  213.190.6.175 Active  pri 100 vIP 213.190              .6.1
.Dec  2 14:43:50.978 CET: HSRP: Fa0/0 Grp 1 Active router is 213.190.6.175, was local
.Dec  2 14:43:50.978 CET: HSRP: Fa0/0 Grp 1 Active: g/Hello rcvd from higher pri Active router (              100/213.190.6.175)
.Dec  2 14:43:50.978 CET: HSRP: Fa0/0 Grp 1 Active -> Speak
.Dec  2 14:43:50.978 CET: %HSRP-5-STATECHANGE: FastEthernet0/0 Grp 1 state Active -> Speak
.Dec  2 14:43:50.978 CET: HSRP: Fa0/0 Grp 1 Redundancy "hsrp-Fa0/0-1" state Active -> Speak
.Dec  2 14:43:50.982 CET: HSRP: Fa0/0 API MAC address update
.Dec  2 14:43:52.178 CET: HSRP: Fa0/0 Grp 1 Speak: d/Standby timer expired (unknown)
.Dec  2 14:43:52.178 CET: HSRP: Fa0/0 Grp 1 Standby router is local
.Dec  2 14:43:52.178 CET: HSRP: Fa0/0 Grp 1 Speak -> Standby
.Dec  2 14:43:52.178 CET: HSRP: Fa0/0 Grp 1 Redundancy "hsrp-Fa0/0-1" state Speak -> Standby
glen.grant Wed, 12/02/2009 - 09:16
   I'm not sure what you are tracking on the gig interface , if it's the serial interface and that is flapping  , with such low hsrp timers it's going to immediately cause a state change , maybe check that serial line.
