Change SMTP sender address Unity Connection 7.x
Nov 20th, 2009
Our customer's SMTP smarthost will only allow incoming email with an SMTP sender address (From: field) in the format of xxx@customer.com. Unity Connection by default will set the sender address of the SMTP notifications to unityconnection@<hostname>.<domainname>. Is there any way we can set this sender address? I have checked all parameter configuration but could not find anything. Does someone know if it is possible to change the sender address?
Many thanks,
Tim
Bradford Magnani Fri, 11/20/2009 - 06:22
  • Cisco Employee,
Tim,
Looks like you're trying to determine how to change the SMTP domain of the UC server.  Here's the process on how to do that.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag247.html#wp1131945
Step 5 To check the SMTP domain, expand System Settings > SMTP Configuration, then click Server.
Hope that helps,
Brad
