UEIME uccx split installation
Nov 20th, 2009
Dears,
In a UEIME split server deployment for uccx,  where database server is installed on a machine and the application, file, services, web components installed on another machine. When i open the default partition (web interface) i get the following error:
Message from the ISAPI plugin:
No backend server available for connection: timed out after 25 seconds or idempotent set to OFF.
Build date/time: Aug 5 2005
Change Number: 616810
please help,
regards,
dchumbley Tue, 12/22/2009 - 11:04
Did you figure out what your issue was?  I am receiving the same error except I have the services all on the same server.  Thanks
Related Content
