CVP standalone SIP transfer
Nov 20th, 2009
Hi all,
in a cvp standalone deployment , i'm trying to transfer a call from CVP to a Cisco SIP phone. However when the transfer element is reached the call disconnects. The call flow is the following:
Cisco ip phone-->Corporate Call Manager-->Voice gateway-->CVP VXML Server (transfer element)
A sip trunk to the gateway is configured on the call manager.
i'm attaching the configuration of the Voice Gateway,
your advice is appreciated,
cheers,
david.macias Fri, 11/20/2009 - 03:51
  • Blue, 1500 points or more
Can you reach the SIP device directly from the IP phone without going through CVP?
david
fabien.damien Fri, 11/20/2009 - 03:59
Hi David,
From a CME softphone configured on the gateway yes. Note that the transfer is successful in CVP comprehensive mode.
david.macias Fri, 11/20/2009 - 04:06
From your call flow I don't see how CME comes into the picture, can you make a call from ip phone > corp CM > VXML GW > SIP device?
david
fabien.damien Fri, 11/20/2009 - 04:41
CME is configured on the gateway. The end sip device is an ip phone on the corporate call manager so i can not simulate a call from corporate ccm to an ip phone connected to it by passing through the gateway. The call will reach the other phone directly using sccp.
I think the problem is with CVP.
