Configuring SSID - VLAN
Nov 20th, 2009
hi,
We have aironet 1121 AP. with only one SSID and only one WEP key.
We need to have two VLAN and corresponding SSID with seperate WEP key for both.
Existing configuration is as given here. Do we need to configure the switch port as trunk and with the native VLAN as that will be configured on the AP?
Do we need to configure AP - gi0  interface as a trunk? Can we keep the bv1 IP address same and add one more SSID and VLAN so that we will not loss the connectivity of the AP. In this case it is DHCP reservation in our DHCP server.
sh runn
Receiving#sh running-config
Building configuration...
Current configuration : 1684 bytes
version 12.3
no service pad
service password-encryption
hostname Receiving
no logging console
ip subnet-zero
ip dhcp pool local-default-pool
   network 10.0.0.0 255.255.255.224
   default-router 10.0.0.1
   lease 0 0 1
no aaa new-model
dot11 ssid RECEIVING
   authentication open
   guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 915020363C01 transmit-key
encryption mode wep mandatory
ssid RECEIVING
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
payload-encapsulation dot1h
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server view dot11view ieee802dot11 included
snmp-server community public RW
snmp-server chassis-id receiving
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Receiving#
Please share the experience.
Any link on cisco.com is highly appreciable.
Thanks in advance.
Subodh
Trending Topics - Security & Network
