Cisco 3745 Digital Modems not passing data.
Nov 20th, 2009
I have configured a Cisco 3745 for both Dialin and out connectivity
the configuration is, an application server designed to communicate directly with RS-232 com ports with attached modems
will utilising an IP based software offering virtual com ports with virtual modems attached.
Dialout is operating correctly where by the Server call a remote host. The redirection software will telnet to the Cisco 3745 and a call is generated from the DM to a remote client device.
Dialin is where the problem occures. The Server is configured to listening for a telnet session from the Cisco 3745.
Inspection shows the call is accepted by the Dial in lines and the autocommand initialises a call to the host server which has a virtual com port with virtual configured modem listening and waiting.
when the remote device calls the Cisco 3745, the call is answered and the session is forwarded to the Server, however almost instantly the Cisco issues a command (+++) to terminate the connection between the DM and the TCP Virtual com port / modem. Data does not pass to the server and the call is dropped.
Cisco 3745
version 12.3
Config Line Info
line 97 98
no motd-banner
no exec-banner
exec-timeout 0 0
no vacant-message
modem Dialin
modem autoconfigure type Mica
autocommand telnet Server 7000 /stream
transport preferred all
transport input telnet
transport output telnet
escape-character NONE
The Com redirect software is supplied by a reputable cisco recommneded vendor
Any direction would be appreciated.
Many Thanks
Larry_s
paolo bevilacqua Fri, 11/20/2009 - 14:23
  • Hall of Fame,
    Founding Member
What happens if you try removing autocommand ?
lskinner@dimens... Mon, 11/23/2009 - 02:56
Removing the autocommand has no effect onn the process.
I have tried to get the Applic Server to create a TCP session to the Cisco Line and
then create an incomming call,
The call is dissconnected and data fails to pass.
paolo bevilacqua Mon, 11/23/2009 - 03:32
  • Hall of Fame,
    Founding Member
Try "no exec".
lskinner@dimens... Mon, 11/23/2009 - 06:49
no exec added to line had no effect on the outcome
the line / router did not attampt to connect to the App Server and so the call timeed out after approx
60 sec, the Virtual Com port did not recieve a connection.  Todate the a connection is established and then terminated with a +++
within seconds.
paolo bevilacqua Mon, 11/23/2009 - 08:14
  • Hall of Fame,
    Founding Member
Try debug modem...
lskinner@dimens... Mon, 11/23/2009 - 08:45
Debug Results
*Mar  1 00:40:20.023: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:43:46.523: Modem 3/0 Mica: configured for Answer mode, with Null signaling, 0x0 tone detection.
*Mar  1 00:43:46.655: Modem 3/0 Mica: in modem state CALL_SETUP
*Mar  1 00:43:46.675: Modem 3/0 Mica: in modem state CONNECT
*Mar  1 00:43:47.059: Modem 3/0 Mica: in modem state LINK
*Mar  1 00:43:50.203: Modem 3/0 Mica: in modem state RANGING
*Mar  1 00:43:52.523: %ISDN-6-CONNECT: Interface Serial1/1:2 is now connected to XXXXXXX
*Mar  1 00:43:54.083: Modem 3/0 Mica: in modem state HALF_DUPLEX_TRAIN
*Mar  1 00:43:56.075: Modem 3/0 Mica: in modem state TRAINUP
*Mar  1 00:43:58.175: Modem 3/0 Mica: in modem state EC_NEGOTIATING
*Mar  1 00:43:58.603: Modem 3/0 Mica: in modem state STEADY
*Mar  1 00:43:58.603:  Modem 3/0 Mica: received ConnectInfo
*Mar  1 00:43:58.619: Modem 3/0 Mica: CONNECT at 31200/28800 (Tx/Rx), V34+, LAPM, V42bis
*Mar  1 00:43:58.907: TTY97: DSR came up
*Mar  1 00:43:58.907: tty97: Modem: IDLE->(unknown)
*Mar  1 00:43:58.907: TTY97: EXEC creation
*Mar  1 00:43:58.907: TTY97: pause timer type 1
*Mar  1 00:44:01.707: Modem 3/0 Mica: in modem state TERMINATING
*Mar  1 00:44:01.707:  Modem 3/0 Mica: received TerminateInfo
*Mar  1 00:44:01.731: Modem 3/0 Mica: in modem state IDLE
*Mar  1 00:44:01.759: Modem 3/0 Mica: DISCONNECT after 00:00:15, due to reason (0x8220) EC rcvd DISC frame.
*Mar  1 00:44:01.759: %CALLRECORD-3-MODEM_CALL_REC_ERROR: DS0 slot/contr/chan=1/1/2, slot/port=3/0, call_id=23, userid=(n/a), ip=0.0.0.0, calling=4660960, called=8200, std=V34+, prot=LAPM, comp = V42bis init-rx/tx b-rate=28800/31200, finl-rx/tx b-rate=28800/31200, rbs=0, d-pad=None, retr=0, rx/tx chars=91/47, bad=0, rx/tx ec=5/2, bad=0, total moh time=0 sec, current moh time=0 sec, moh count=0, moh status=0x0, call waiting retrains=0, moh req=0, encoder/decoder state=0xFF/0xFF, rx/tx comp ratio=0.00:1/0.00:1, rx/tx dict reset=0/0, time=15, finl-state=STEADY, disc(modem)=8220 Rx (line to host) data flushing - OK/EC condition - locally detected/receiv
The image indicates the call from the Virtual interface perspective. Red indicates information  originating from the Router to the Virtual modem
The edge device is either sending the +++ or the router DM is sending the +++ because it cannot understand the data from the remote modem.
lskinner@dimens... Mon, 11/23/2009 - 08:46
Debug Results
*Mar  1 00:44:01.759: %CALLRECORD-3-MODEM_CALL_REC_ERROR: DS0 slot/contr/chan=1/1/2, slot/port=3/0, call_id=23, userid=(n/a), ip=0.0.0.0, calling=xxxxxx, called=8200, std=V34+, prot=LAPM, comp = V42bis init-rx/tx b-rate=28800/31200, finl-rx/tx b-rate=28800/31200, rbs=0, d-pad=None, retr=0, rx/tx chars=91/47, bad=0, rx/tx ec=5/2, bad=0, total moh time=0 sec, current moh time=0 sec, moh count=0, moh status=0x0, call waiting retrains=0, moh req=0, encoder/decoder state=0xFF/0xFF, rx/tx comp ratio=0.00:1/0.00:1, rx/tx dict reset=0/0, time=15, finl-state=STEADY, disc(modem)=8220 Rx (line to host) data flushing - OK/EC condition - locally detected/receiv
The edge device is either sending the +++ or the router DM is sending the +++ because it cannot understand the date drom therek
paolo bevilacqua Mon, 11/23/2009 - 10:26
  • Hall of Fame,
    Founding Member
Can you try a different client modem or configure it differently.
And we did not mentioned MICA firmware to be latest ?
