MGCP endpoint registration rejected
Avinash Gupta Fri, 11/20/2009 - 07:59
Check the Domain name, It should be same as Router Host name, or you may change the Host name of the router (MGCP Gateway) & delete old one in call manager & reregister again.
iptuser55 Fri, 11/20/2009 - 09:03
Set "debug mgcp packets" on the GW and check what the response is when the GW tries to register
200 all good
500 - Name being sent by the GW is incorrect
Check if  IP Domian name xxxxx is set on the GW is so, this needs to be added to the GW Host name in CCM
IP domain name CISCO.COM
So the GW name in CCM must be GW1.CISCO.COM
if ip domain name is not set then confirm what the Host name is in both CCM and GW
Oleh Doroshenko Mon, 06/17/2013 - 23:54
Dial-peer voice xxxx pots
port x/x/x
service MGCPAPP
The trick is that voice gw do not check service name for existence, so if u misspelled it - nothing will work
