Can any on help create a xml file for the following sip vendors config
Answered Question
Can some one help with a xml file for the SIP setup on a UC 500?
The outgoing SIP URI : sipconnect.ipcomms.net
Username: testtest1
Password: testtest1
the incoming is SIP URI : sipconnect.ipcomms.net but has a different login and password
Username: testtest2
Password: testtest2
____________________________________________________________
This is the sample config they gave me...
Sample VoIP Entry - H323 - Outbound Service
Sample POTs Entry - Inbound Service
dial-peer voice 6781475 pots
description IPC
huntstop
destination-pattern 6784601475
no digit-strip
port 0:D
dial-peer voice 1234 voip
description IPC
huntstop
destination-pattern . or .T
progress_ind setup enable 3
session target ipv4:xxx.xxx.xxx.xxx
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g729r8
tech-prefix yyyyyyy
xxx.xxx.xxx.xxx is the IP address of IPC's destination gateway. yyyyyyy is the
prefix assigned to your account.
Sample VoIP Entry - SIP - Outbound Service
description IPC
huntstop
destination-pattern yyyyyyy. or yyyyyyy.T
session protocol sipv2
codec g729r8
yyyyyyy is the prefix assigned to your account
Correct Answer by Maulik Shah about 7 years 8 months ago
Attached is the first pass - give it a shot and let me know. If you confirm this all works we can post this for everyone to use.
Info on how to upload a template is below:
https://www.myciscocommunity.com/docs/DOC-9168
May need some more info to generate this file (note assume you will do the testing) - here is the typical list - items in bold are where we need your input
Name of SP: IPCOMMS
Dial Plan Locale (Country)
Fields to show on the SIP Trunk tab:
Proxy Server (Primary) Y/N
Proxy Server (Backup) Y/N
Registrar Server Y/N
Outbound Proxy Server Y/N
Digest Authentication (username / password) Yes (per your note below)
Other:
Voice codec: G729r8 (per your note below)
Fax protocol  T.38 / G711ulaw upspeed / G711alaw upspeed
DTMF RFC 2833  with RTP payload type 101 (default) - can change to any vaue from 96 to 127
Register all DIDs Y/N
If register all DIDs, then - all DIDs have same password OR unique password
DSCP marking Signaling cs3
DSCP marking RTP ef
Also, did not follow the different usernames / passwords for inbound versus outbound - the UC500 does not authenticate inbound SIP requests using username / password but using the IP address of the SIP proxy at the provider
Overall Rating: 5 (2 ratings)
Correct Answer
Maulik Shah Fri, 11/20/2009 - 10:29
  • Silver, 250 points or more
Name of SP: IPCOMMS
Other:
DSCP marking RTP ef
Name of SP: IPCOMMS
Dial Plan Locale (Country) North America
Proxy Server (Primary) sipconnect.ipcomms.net
Proxy Server (Backup) N
Registrar Server sipconnect.ipcomms.net
Outbound Proxy Server sipconnect.ipcomms.net
Digest Authentication (username / password) Yes (per your note below)??  YES
Other:
Voice codec: G711ulaw (per your note below)
Fax protocol G711ulaw upspeed
Register all DIDs Y
DSCP marking RTP ef
