Warning message
RME Netconfig Jobs
Answered Question
Nov 20th, 2009
I'm looking to deply "no mop enabled" and "no lat enabled" via Netconfig to some of our device interfaces.
Is the option "port based" the right option to choose since this an interface level command?
I chose 100 mbps Ethernet, 1 Gbps Ethernet port, and links ports
Correct Answer by Joe Clarke about 7 years 9 months ago
There is not.  You will have to schedule compliance jobs.  However, you can schedule a compliance check job to run automatically, and you can choose to run it on a dynamic group of devices.  So, essentially, RME can scan newly added devices, but it just won't happen as they are added.
Yep, provided the name of the interfaces contained the word, "Serial".
In Netconfig, create a new Netconfig job, and select Device based from the first screen.  Then you can use the Ad hoc template to fill out the necessary parameters.
No, the option will be device-based as port-based is only applicable for switch ports, not router interfaces.  If there are only specific interfaces to which these commands should be deployed, create a device-based template, and specify the interfaces and the commands.  If, however, you want to deploy the commands to a whole class of interfaces, it would be easier to use the baseline compliance feature of RME.  Using this, you can create a template with a submode such as:
interface [#.*Ethernet.*#]
Then under that submode, add:
+ no mop enable
+ no lat enable
Correct Answer
Joe Clarke Fri, 11/20/2009 - 10:05
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
+ no mop enable
+ no lat enable
dionjiles Fri, 11/20/2009 - 10:08
Okay I guess I was reading the documentation wrong.....let me get a template created since this is going out to router interfaces.
Correct Answer
Joe Clarke Fri, 11/20/2009 - 10:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dionjiles Mon, 11/23/2009 - 11:37
If I wanted to do Serial interfaces would this syntax work?
interface [#.*Serial.*#]
+ no mop enable
+ no lat enable
Correct Answer
Joe Clarke Mon, 11/23/2009 - 11:50
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dionjiles Mon, 11/23/2009 - 12:14
Wow I have been really scared to use RME compliance manager until now.....this makes life so much easier.
I wish they was a way when devices get add that Compliance manager would check the device, it could be I haven't
had the chance to really read up on it.
Correct Answer
Joe Clarke Mon, 11/23/2009 - 12:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dionjiles Mon, 11/23/2009 - 12:27
Thanks for the prompt response....maybe in LMS 4.0?
Joe Clarke Mon, 11/23/2009 - 12:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, I don't think so.  Definitely more is going into compliance management in 4.0, but I haven't seen a trigger-based compliance check yet.
