Router ARP Requests to an offline host...
Nov 20th, 2009
How can I find out why my default gateway router (Cisco 857) keeps sending out ARP requests for the MAC address of a host that is offline?
When I sniff packets on the internal LAN, I continue to see these broadcast ARP requests coming from this router, asking for the MAC address of whoever it is that has this particular IP address. It never gets a response back, because there is no such host that is active on our LAN. Yet the ARP requests continue...
Any guideance would be greatly appreciated. Thanks!
Jon Marshall Fri, 11/20/2009 - 11:00
Peter
Check the config to see if there are references to the IP address that the router is arping out for
Jon
p3t3rt0sh Fri, 11/20/2009 - 11:07
There is nothing in the running-config that is referencing the particular IP address...
p3t3rt0sh Fri, 11/20/2009 - 13:08
I have no recollection of what this host was. It's IP address does not fall under our DHCP scope, so it was staticlly configured, whatever it was.
I'm thinking of configuring a client with this IP address and sniffing the packets to see if I can figure out what kind of traffic the router wants to pass to it.
Richard Burts Sat, 11/21/2009 - 03:44
The symptoms that you describe of the router ARPing for this address repeatedly suggest that something is sending packets to this router for that destination address. There are a couple of ways that you could investigate what this is:
- your suggestion of putting that address on a client and sniffing would work.
- if you have netflow configured on the router you might find the source address and protocol ports in the netflow data.
- you could configure an access list on the router interface with a permit statement for that destination address and the log parameter so that the router will create log messages for the packets which would have identifying information.
Rick
