planning to purchase asa-5510 with ips. Need advice.
Nov 20th, 2009
I am planning to purchase 5510 with ips for a small office: 7 internal users and 15 VPN (there will be never more than 5 simultaneous VPN connection)
Looking for right part numbers for appropriate bundle for the device and licenses required. Don't want to buy more than needed in advance.
Not easy task
I need ASA-5510 with ISP module and 15 SSL VPN licenses, also SmartNet package that will cover all with low as possible coverage time (ex. next business day replacement, 8x5 etc) Support should be for Firewall, VPN and ISP. There are plenty of packages with abreviation codes and  sometimes without description.
May be buying ASA5510 (50 users) and SSM-10 module separately will be cheaper?
Will appreciate your help...
