11-20-2009 12:02 PM - edited 03-06-2019 08:40 AM
hello,
what is the 64mb bootflash form on the sup engine 5? dimm or cf?
i cant find any layout/image of sup 5. if someone can help pls...thanks
Solved! Go to Solution.
11-20-2009 07:28 PM
I apologize -- your are right that the 512MB DIMM is for the Supervisors memory. However, there is another built in 64MB flash module, in addition to a Compact Flash card slot, that you can use for storing the IOS image. Bootflash is the builtin module, and Slot0 refers to the CF card slot.
Here's a better look specifically at the Supervisor V:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/78_15590.html
--Brandon
11-20-2009 04:31 PM
The default is a SODIMM memory chip installed on the Supervisor module, but the 4500 Supervisor V also has a slot for a compact flash.
See http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/module/guide/01overvw.html#wp1085814 for additional info.
Good luck,
Brandon
11-20-2009 07:02 PM
if the default is in sodimm form of 512mb, then how
- to install/replace it with a compact flash form
thanks
11-20-2009 07:20 PM
hi,
i think the;
-512 sodimm is the system dram
-64 mb compact flash is for the bootflash
do we have here any detailed docu about sup 5...couldnt find any..thx
11-20-2009 07:08 PM
You don't necessarily need to remove the DIMM, unless it's already bad or you have some other reason. You can use this article to show you how to set the boot parameters to boot off the CF card:
Good luck!
Brandon
11-20-2009 07:28 PM
--Brandon
