Hum 1.1 does not collect information CPU router 7507VXR/RSP4
Answered Question
Nov 20th, 2009
Hello everyone, HUM has not been possible to  extract information from computer's CPU. I have not found more information on the cisco.com  website or anywhere.
According to official papers only need the mibs  CISCO-PROCESS AND ENTITY.
Please  your help and comments.
Guilliano Palavecino Rojas
Enginner Support Communications
Adexus S.A
Correct Answer by Joe Clarke about 7 years 3 months ago
Exactly how are you defining your poller in HUM?  What version of IOS is the 7507 running?
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 11/20/2009 - 12:37
g.palavecino Mon, 11/23/2009 - 05:17
First of all, correct that the model of router is 7507/RSP4 (x2) with IOS 12.2 (14) S19.
The way of configuring the poller,
- HUM
- Poller and template management
- Poller management
- Create
- Device selector (rete1, rete2)
- Poller detail
-name: cpu_test_7507
-polling interval: 5 min
- Templates
-cpu utilization
- Selected templates
-cpu utilization
NEXT
Available instances = 0
Also, selecting "poll all instances" I have available two instances, but at the end of the poller does not collect data.
Joe Clarke Mon, 11/23/2009 - 07:55
Okay, I think you're seeing my bug CSCtb68766. post the output of SNMP Walks for the following objects:
1.3.6.1.4.1.9.9.109.1.1.1.1.8
1.3.6.1.4.1.9.9.109.1.1.1.1.5
Joe Clarke Tue, 11/24/2009 - 08:51
This looks good.  You're not seeing my bug.  Start a sniffer trace filtering on all SNMP traffic to this 7507, then try recreating your poller.  When it fails, post the sniffer trace file.
Joe Clarke Thu, 11/26/2009 - 10:17
I need to see the binary sniffer file so I can inspect all fields in each packet.
Joe Clarke Thu, 11/26/2009 - 11:31
Since the 7500 doesn't support the ENTITY-MIB, it is possible the multiple CPUs are triggering a bug in HUM.  Each CPU has the same physical index of 0 (which is fine based on the MIB definition).  However, HUM tries to map the physical ID to a textual description of the CPU.  Unfortunately, I do not have a 7500 with which I can test this.  All of my single-CPU devices which have 0 CPU physical indexes work fine.
Post the upm_process.log after reproducing this problem.  It may be possible to spot the problem, but you need to open a TAC service request so that this can be analyzed in the lab.
g.palavecino Thu, 11/26/2009 - 12:05
ok, thank you very much. I will escalate the issue with the TAC and notice them.
