How to add another language to CUE?
Nov 14th, 2009
Hello... sorry to revive this thread but I have another dual language issue. Thank you for all the previous helpful answers.
The issue now is how to add another language to CUE. I have upgrade to CUE 7.1 and completed the prompts and the script which are all working fine except for some minor fine tuning.
The script allows for implementing a second language in the Set Contact Info step but the prompts have to be saved in the correct language directory. The problem is when I try to save the prompt in the relevant directory I get an error message that the language is not installed. I followed the config guide to add a second language but the only files I find have a .prt1 extension which can't be added.
Any suggestions on how to install the second language?
The platform is UC520 ISE.
