How to have H-REAP broadcast only specific locally switched SSID's?
I'm new to this H-REAP configuration, but in the main office we have about 6 WLAN's.  I have a remote office which I want to have 2 new WLAN's and have them switched locally.  How can I only have the H-REAP AP's at this site only broadcast those 2 SSID's vs all 8?  I haven't really read anything about using AP Group VLAN's with H-REAP or know if that's even possible, but is this a possibility and if no,t what would you recommend?
Thanks for the help!
I may create another topic - but here it goes...
I've decided to try to use an existing WLAN in the H-REAP config...
-I've joined the AP to the remote controller, assigned it an IP, put it in H-REAP mode.
-I chose a WLAN, enabled local switching
-I went into the AP, configured the native VLAN, however, I CAN NOT change the vlan of the WLAN listed.  It always goes back to default.
I verified the vlan exists on the switch, is routable, etc, the switch port is a member of that vlan, it is set as a trunk w/ 802.1q, etc.
Any ideas on what would cause this?
I am SOO close   Thanks!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
