11-21-2009 05:05 AM
for example now I'm using
translation-rule 44
Rule 1 ^8014 801439 ANY unknown
Rule 2 ^123 801439 ANY unknown
Could you suggest me what rule 3 have I to add to match case where digit aren't present ?
These are what I can use with the actual IOS ( voice tramslation-rule option aren't available)
^(\^)?(\+)?([0-9,ABCD.*%?#]+)$
I think that this IOS is quit old
I tried to use c3620-jsx-mz.122-40.bin but after relaod a got a memory error and I had to go back to c3620-is-mz.122-13b.bin"
XXXXXXX#show mem
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 61D42320 31186144 12413784 18772360 17918756 17610592
I/O 3B00000 5242880 2945004 2297876 2220656 2295900
XXXXXXX#show ver
IOS (tm) 3600 Software (C3620-IS-M), Version 12.2(13b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 21-Feb-03 09:52 by pwade
Image text-base: 0x60008930, data-base: 0x61112000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
XXXXXXX uptime is 3 weeks, 4 days, 3 hours, 51 minutes
System restarted at 09:11:24 CET-1CEST-2 Tue Oct 27 2009
System image file is "flash:c3620-is-mz.122-13b.bin"
cisco 3620 (R4700) processor (revision 0x81) with 60416K/5120K bytes of memory.
Processor board ID 18119770
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
62 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
11-21-2009 06:25 AM
Either add RAM to support newer IOS, or replace the router altogether.
11-21-2009 06:41 AM
1st of all thanks to this quikly answer
About translation Rule with the actual IOS c3620-is-mz.122-13b.bin
Have I to assume that isn't possible to create a rule to match a case when calling is null or not present or is there a way ?
thanks again
