bootflash on sup v 2ge
Nov 21st, 2009
hello,
-is there any sup 5 (2ge) documentation showing where the bootflash and system memories are?
-i could see some pictures but i couldnt see anything showing the bootflash. This is i assume that the bootflash is a 64mb compact flash.
vvasisth Tue, 12/08/2009 - 01:44
You are right Sup V has 64-MB onboard Flash memory (in addition to removable Flash memory)
The Flash port accepts a Type 1 compact Flash card. You can use it for file transfer tasks such as loading a new software image. The Flash card is optional and can be obtained from third-party suppliers.
For more information, refer to Using the Compact Flash on the Catalyst 4000 Family Supervisor Engine III and IV at the following URL:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_2788.html
I am not sure if i got your 1st question right but the below giving link might help you :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/78_15590.html#wp82077
regards,
Varun
