Incoming PSTN UK BT (POTS) dial problem
Answered Question
Nov 21st, 2009
I have 2 IP phones 7940's connected to a C1760 router configured with 2xFXS ports and 2x FXO ports running CME v4.1
The 2 phones can each complete a successful outgoing call over the pstn line. When an INCOMING call is being received the caller hears one ring and nothing else?
Correct Answer by William Bell about 7 years 4 months ago
Looks like you are missing dial-peers on the POTS lines to accept inbound calls.  Example:
dial-peer voice pots 100
direct-inward-dial
incoming called-number .T
port 1/0
direct-inward-dial
port 1/1
This assumes you don't require translations to get to extension 1000 and 1001.
HTH.
Bill
Overall Rating: 5 (2 ratings)
Correct Answer
William Bell Sat, 02/20/2010 - 17:25
  • Purple, 4500 points or more
direct-inward-dial
port 1/0
direct-inward-dial
port 1/1
HTH.
Bill
stev1efaill Sun, 02/21/2010 - 07:22
I was being a bit dim and not reading the CCNA Voice guide
Page 271 of the Cisco Press guide:-
When an incoming signal is detected CME doesn't know what to do with it unless you specify a PLAR (Private Line Automatic Ringdown)
config:-
voice-port 1/0
cp-tone GB
connection plar 1000
voice-port 1/1
cp-tone GB
With this config any of the 2 ports connected with a standard PSTN phone line will be forwarded instantly to x1000 i.e a receptionist if you can afford one!
Another important note is the cp-tone to the correct country otherwise the incoming caller knows they have dropped on a call system.
All I have to work out now is a timeout, if the incoming call is closed x1000 keeps ringing for approx 2 minutes
thanks
Steven
Related Content
