ipsec vpn configuration in ADSL line
Answered Question
Nov 22nd, 2009
my diagram is
isp line---adsl router(dynamic ip)--- asa5505----vpntunnel---- asa5520(static ip)
i connected from ADSL to asa5505 so adsl local is 192.168.1.0 network and asa 5505 outside also the same network
so i need to configure site to site vpn between two asa ..
so i need to route any traffic on router or it will automatically route the vpn traffic in ADSL line side.
Correct Answer by grant.maynard about 7 years 3 months ago
i think this is just a difference in the OS: v6.3 shows QM_IDLE while v7.x shows MM_ACTIVE.
Nothing to worry about.
Overall Rating: 5 (1 ratings)
spremkumar Sun, 11/22/2009 - 22:09
The schematic which you have posted is not clear, can you make a sample diagram and post it out here with your requirement.
regds
zeuscyril Mon, 11/23/2009 - 23:54
hi prem,
i got the solution by own.
but i am having one doubt ,
my tunnel is up i can communicate both the sides but my "sh crypto isakmp sa " showing status as MM_Active is not showing QM_IDLE
why it is like that it ll give any problems on vpn or what is the reason for that?.
Correct Answer
grant.maynard Tue, 11/24/2009 - 10:18
zeuscyril Tue, 11/24/2009 - 21:39
hi all,
i need configure 17 sites site to site vpn one place is central that is having static ip all other sites are dynamic ip .
so i created dynamic map in centeral asa 5520 , so i need to create 17 different vpn profile for the sites or one profile is enough to get connect with the sites.
