What are the Hot Items that need our attention?
Nov 20th, 2009
We've received a lot of great feedback from all of you so far on the new changes.  I'm pleased to say that most of it is pretty positive.  That said, there are some things that I feel we need to explain better.  For example, the way you grant points has changed and we need to make sure the method is clear to make sure you don't give a 1 star when you meant to give 5.  We've created a Hot Items wiki doc in the Help section to address these in real time as they come up.  The rating method will be posted there shortly.
Use this discussion to tell us what the other Hot Items are as you use the new site.  We will continue to add to the wiki doc as needed.
Cheers,
Tim Albright
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 11/20/2009 - 09:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Tim,
So far so good!
I already mistakanly gave my friend Jon a 1 instead of a 5, so thanks for pointing out what an idiot I am
Just an FYI
Maria pointed out a very nice fix for anyone that is finding the new site
slow and/or are experiencing "script errors"
From the page > Account > Preferences > Thread page View > ** change to Flat
This really has enhanced the overall feel for me
Cheers!
Rob
Timothy Albright Fri, 11/20/2009 - 09:23
rob.huffman wrote:
Hey Tim,
So far so good!
Just an FYI
Cheers!
Rob
Rob,
Totally right about Maria's find on the "Flat" setting.  It helps overall performance for obvious reasons.  We'll add that to the Hot Items.  If you can, take a quick look at the Hot Items doc to see how we did on the description.  Trying to be more responsive than fancy, but I want to make sure it gets the method across.
Cheers,
Tim
Rob Huffman Fri, 11/20/2009 - 09:32
  • Hall of Fame,
    Founding Member
Hi Tim,
Yes, that looks pretty good for sure. I might add something like;
Of the 5 Stars shown, the most Right hand Star = 5 (Highest rating)
Of the 5 Stars shown the most Left hand Star = 1 (Lowest rating)
be careful to check before you click on a Star as the rating cannot be changed after it has been entered (as Rob can attest to)
Cheers!
Rob
Monica Arroyo Fri, 11/20/2009 - 10:48
Rob,
Thanks for the suggestions. I will go ahead and make the edits.
Kind Regards,
Monica Lluis
CCIE 7509
Cisco Support Community Moderator
Rob Huffman Fri, 11/20/2009 - 11:17
  • Hall of Fame,
    Founding Member
Thanks Monica,
I even managed to hit the right Star this time
Cheers!
Rob
Reza Sharifi Fri, 11/20/2009 - 14:01
    2017 LAN
Is there a specific Idle time out for the new Netpro? I get logged out often.
With the old one, I was always logged in and did not have to login every hour or so.
Reza
Edison Ortiz Sat, 11/21/2009 - 11:49
  • Hall of Fame,
    Founding Member
Hi Tim,
I noticed Cisco Employees have lost their star and the Cisco logo is used as the placeholder.
Any plans on adding the star on Cisco Employees?
Also, it seems I lost points that were associated to my previous account 'EdisonOrtiz'.
Internally within Cisco, the point total is correct while externally under my ediortiz account is not.
Edison
Timothy Albright Sat, 11/21/2009 - 12:24
ediortiz wrote:
Hi Tim,
Edison
Hi Edison,
We honestly don't have plans right now to bring back the stars for Cisco employees.  Let me look into that and get back to you.  Not sure of the difficulty level.  That said, we will be looking for a variety of ways to recognize Cisco contributors.  Many of the (non-Cisco) forum users have asked about this, so we will be working on it.
As to the different accounts, we have run into this before.  Dan should be able to sort this out for you.
Thanks for your feedback.
Cheers,
Tim
Daniel Bruhn Sat, 11/21/2009 - 18:15
  • Blue, 1500 points or more
Hi Edison,
I have completed the merge of your accounts.  Please let me know if you see any issues.
Cheers,
Dan Bruhn
NetPro Community Manager
Edison Ortiz Sun, 11/22/2009 - 19:34
  • Hall of Fame,
    Founding Member
Dan,
It's fine now thanks
Edison Ortiz Sat, 11/21/2009 - 11:58
  • Hall of Fame,
    Founding Member
Hi Tim,
Is there a plan to bring back the section where all unanswered questions were located?
Currently, you can filter on 'answered' questions but this provides a false positive as it categorizes 'answered' questions on only rated threads.
Even if a thread is being properly answered but no rating was given is classified as 'unanswered'.
We need a filter for threads with no replies as the old netpro had.
Edison
Timothy Albright Sat, 11/21/2009 - 12:19
Hi Edison,
We still have the "unanswered questions", however, the "widget" for this is on the Overview Tab of any topic (e.g., IP Telephony).  At least for now, we can't place it directly on the Forums tab.  That's a limitation of the system.  Take a look and let me know what you think.  It's another "click" away but it's there.
Cheers,
Tim
Rob Huffman Sat, 11/21/2009 - 18:44
  • Hall of Fame,
    Founding Member
Hi Tim/Dan,
I find it quite sad that Cisco employees will not be recognized
with the Badges that they have earned
We all know that this is not fair and diminishes the overall community.
Can't these fine folks have both the Cisco Logo and their Star shown in
their profile. It seems like a reasonable compromise to me.
Cheers!
Rob
Daniel Bruhn Sat, 11/21/2009 - 18:55
Hi Rob,
I promise we will make this a top priority.  It's important everyone gets recognized for their efforts on NetPro.
Cheers,
Dan Bruhn
Rob Huffman Sun, 11/22/2009 - 08:44
  • Hall of Fame,
    Founding Member
Thanks Dan!
I am sure that there was some rationale for excluding the Star/Badge
for Cisco employees, but it makes no sense to me. We want everyone
to participate and feel welcome, we also know that these employees have spent
countless hours earning this recognition. I don't want to "beat a dead horse" here
but the sooner this oversight is remedied the better for all involved. Lets move the
community forward with all people treated as equals
Get some rest my friend!
Cheers!
Huff
Timothy Albright Sun, 11/22/2009 - 18:32
Hi Rob,
Agree this needs to be a priority.  I know you (and others) have championed this for some time.  May not happen overnight since we'll need to make adjustments, but we definitely agree with the sentiment.  By the way, I love the avatar.
Cheers,
Tim
