Can't edit device on CS
Answered Question
Nov 22nd, 2009
I've manually added a device on cisco works through CS (Device and Credentials -->Device Management)
On RME is says it failed to collect inventory and config archive. The message is: could not access "pix" via snmp...
I want to edit the device credentials/configurations on Common Services but device is not showing up. Does anyone know how can I fix it?
I have tried re-adding it but makes no difference.
Correct Answer by Joe Clarke about 7 years 5 months ago
Is LMS integrated with ACS?  If so, does the device show up under the Common Services > Device and Credentials > Reports > Devices not configured in ACS report?
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 11/22/2009 - 17:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Joe Clarke Sun, 11/22/2009 - 21:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to add this device's IP to your ACS server as a TACACS+ client.  The device does not need to use AAA services, but the ACS must be aware of the device.  After adding the device, logout of LMS, then log back in, and the device should be manageable.
