11-22-2009 06:15 PM - edited 03-06-2019 08:41 AM
Can anyone help with this easy answer? In lehmans terms would be nice
Solved! Go to Solution.
11-23-2009 10:42 AM
cisco_himg wrote:
Ok cool. they all come back to the backbone on a Gig switch. so i guess since there are two channels, it will be 2 Gig connections coming back to me, correct?
If there are 2 physical links in each channel and the physical links are 1Gbps each then yes your portchannel is 2Gbps.
Jon
11-22-2009 06:57 PM
With PortChannel or what is commonly referred to as 802.1ad link aggregation, you aggregate multiple links together. For example, you aggregate multiple 1Gig or 10Gig interfaces together to have access to more bandwidth. The Maximum number of links that you can bundle together is 8.
A regular trunk link is a link that carries multiple VLANs.
Reza
11-22-2009 08:00 PM
Trunk link is just a single line that carry one or more VLANs. It's called "trunk" because it was based on the same theory that of the large phone cables called "trunks".
Bundle up two to eight trunk lines and it's what is called as an Etherchannel. There are two types of port etherchannel: FastEtherchannel or GigabitEtherchannel.
11-23-2009 02:19 AM
Trunk link is, as Leo said, a single link usually between 2 switches that carries the traffic of multiple vlans.
A portchannel is a number of links, usually between switches, that are bundled together and treated as one single link by STP (Spanning tree). Because it is treated as one single link even though there are multiple physical links in th bundle none of the indiviual physical links are blocked by STP. This means you can have increased throughput but just as importantly if one of the physical links fails there is no STP reconvergence.
A portchannel can be a bundle of links that are all in the same vlan or it can be a bundle of links that are all trunk links. It can't be a combination of both.
Jon
11-23-2009 09:17 AM
Thanks guys!
How can i tell the speed of the port Channel compared to my regular trunk links? Or is there a way?
11-23-2009 09:22 AM
I forgot to give a little more detail...
I have 6 closets, in which 4 are running portchannel, and 2 are just regular trunk links.
THe 4 that are port channel are two fiber channels each coming from a Gig switch going to their respected closet. So each of the 4 closets have two fiber cables going there.
The 2 trunks are just one single fiber cable going to their respected closet.
Ok, so how can i tell the throughput on the port channels compared to the regular trunk links.?
11-23-2009 09:44 AM
Your port channel speed will be whatever the interface speed is that connects the 2 boxes . It is not an aggregate . If you have say a fastethernet port channel then your link speed will only be 100 megabits per second . A ether channel gives you more pipes for your data but does not increase your transfer speeds . A given conversation will only traverse a single link in that bundle so your speed is 100 meg.
11-23-2009 09:46 AM
11-23-2009 10:42 AM
Jon
