How to get 300 mbps on Cisco LAP1142N without WLAN Controller
Nov 22nd, 2009
Anyone using Cisco LAP1142N without Wireless LAN Controller and getting 300mbps throughput? I am only using 5 GHz (Manually Disabled 2.4) but i am getting only 144 mbps max throughtput. It would be great if someone can help me to achive around 300 mbps from this AP.
Thanks in advance.
Leo Laohoo Sun, 11/22/2009 - 20:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You need to configure either Open authentication or WPA2/AES to enable 802.11n.
mustafiz Sun, 11/22/2009 - 21:01
Thanks for your reply. Yes, using Authentication-> open. Under the Radio interface using Channel Width 40-above. Checked with a laptop and it connects with 144 mbps and not getting more then that.
Here is a part of the config:
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$0M/H$HIkGshtMt9w5q.KqNvMQf/asdf
no aaa new-model
no ip domain lookup
dot11 syslog
dot11 ssid TestN2
   authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid TestN2
antenna gain 0
no dfs band block
speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel dfs
station-role root
bridge-group 1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
