What is preferred ?Static route or Route MAP----Thanks
Answered Question
Nov 22nd, 2009
I have static route and route map configured on this Cisco 4000 series switch for the same destination(172.24.0.0/16) from same sources(10.32.0.0/16).Which path will traffic take to reach the destination.This SWITCH has VLAN interfaces for 144.1.4.x , 10.32.254.x  ,10.32.0.x
ip route 172.24.0.0 255.255.0.0 144.1.4.85
access-list 1 permit ip 10.32.0.0  255.255.0.0 172.24.0.0 255.255.0.0
route-map BRANCH permit 10
match ip address 1
set ip  next-hop 10.32.254.5
Correct Answer by Giuseppe Larosa about 7 years 2 months ago
it depends from the set action used in the route-map if it doesn't use the default keyword traffic is policy routed unless next-hop is unreachable.
Clearly a mistyping error:
this should be an extended ACL and you should use wildcards so the line could be written as
access-list 101 permit ip 10.32.0.0 0.0.0.255.255 172.24.0.0 0.0.255.255
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Nagendra Kumar ... Sun, 11/22/2009 - 21:09
Policy based routing will be preferred over any routing table entry.
Only when your PBR fails, the router will look into routing table (irrespective of static/dynamic routing entry).
HTH,
Nagendra
Steven Glogger Mon, 11/23/2009 - 03:34
if you're using PBR please watch:
set ip next-hop
here we have:
  • does next-hop exists in routing table? then route according to PBR entry
  • if not: use routing table (e.g. default route)
set ip default next-hop
here we have:
  • next hop exists in routing table? if so: route according entry in routing table.
  • if not: use PBR route
Correct Answer
Giuseppe Larosa Mon, 11/23/2009 - 02:54
Hope to help
Giuseppe
