setspn command for Unity networked servers
Nov 23rd, 2009
In GSM tool while trying to move a subscriber from server A to Server B I am having issues connecting to Server B, i.e login to Server A , use GSM and try and Move the user to Server B - confirms that users can be moved but then it  fail's connecting to ServerB.
I am logged into serverA and  using the command 'setspn -A MSSQLSVC /ServerB :1433 domain\account' - this fails.
Should the account be the account I am login in to the box with or what the sql services are running with? Should the server be Server B or should it be Server A in the command?...thanks
