Hunt Piolt
Nov 23rd, 2009
Dear all,
I have CCM 4.2.
I want to add new three ip phones in my three gates for my plant and i ask :
If i can make the three extensions to be Non-DID numbers and at the same time to be located in a hunt group with one hunt pilot with DID extension to be called from outside, at the same time to be called from inside the plant with its  Non-DID number.
donovan222 Mon, 11/23/2009 - 06:38
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
You’ll need to add your Hunt pilot 1519999, Create the 3 ext 152000, 152001 and 152002 and add them to the hunt group. Add the EXT for the DID 801-555-1212 EXT: 51212 and forward it to the pilot number 1519999.
Ahmed Yassin Mon, 11/23/2009 - 06:53
Ok, thx a lot, but, how i add DID number(which will be forworded to the pilot) without phone set
Related Content
