Enabling SSH and disabling Telnet
Answered Question
Nov 23rd, 2009
I am trying to enable SSH on a 3560G switch so I can disable Telnet.
Some have mentioned to do an "sh ssh" to see if I have ssh on the switch. It doesn't show. I also have done "transport input ssh" and ssh isn't a valid input method.
So I decided to upgrade the IOS on the switch. I am now at 12.2(52) SE.
But I still cannot configure SSH. I get the same results as mentioned above.
Since this is the latest version of IOS can I not assume that it contains SSH? Or do I need to download a different version of IOS that specifically has SSH in it?
Thanks for your help
Correct Answer by Farrukh Haroon about 7 years 6 months ago
There are two versions of Catalyst Switch images (K9/SSH and WIthout SSH). If you do a 'show versi
on' it will display the current version of the IOS running on the switch. If you are running a non-ssh version, you need to upgrade to a ssh (K9) image.
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Mon, 11/23/2009 - 12:21
  • Red, 2250 points or more
Farrukh
king06aaa Mon, 11/23/2009 - 12:30
I am at 12.2(52) SE. I downloaded it as a .TAR file.
I see now, I downloaded the wrong file.
Farrukh Haroon Mon, 11/23/2009 - 12:43
Yup, you need a K9/CRYPTO image, e.g:
c3560-ipservicesk9-mz.122-52.SE.bin
You can use the feature nagivator to search for images with 'Secure Shell' support:
www.cisco.com/go/fn
It can be either .tar or .bin does not matter. The .tar image includes the web-gui files (alongwith the .bin IOS image) and does not affect the SSH capability.
Farrukh
king06aaa Mon, 11/23/2009 - 12:50
That's a handy site. Didn't know it existed.
