11-23-2009 06:39 AM - edited 03-11-2019 09:41 AM
Does anyone know if it is possible to trigger a failover in case a certain IP is unreachable? I know you can do that based on interface state but I would need to do that based on a gateway reachability.
Christophe
11-23-2009 06:46 AM
Christophe
Christophe
Yes you can do this -
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ip.html#wp1090243
Jon
11-23-2009 07:03 AM
Jon,
Thanks for your answer but it is not what I was asking for. I don't want to add tracking on a route, I want the active ASA to failover to the standby ASA in case an IP is unreachable. Is it possible?
Christophe
11-23-2009 07:17 AM
c.lemaire wrote:
Jon,
Christophe
Christophe
My sincerest apologies, i read the question a little too quickly.
As far as i know there is no way to do this at the moment. What you need is something like EEM (Embedded Event Manager) which is available on Cisco routers and allows you to execute commands on a router based on the results of a tracked object. But there is nothing as yet like this on the ASA.
Jon
