Media Master control can't install/access on Unity 7.0.2 server
Nov 23rd, 2009
In Unity (7.0.2) Server (win2003 SP2) when i go to System Adminstrator page to subcribers page it appear the pop up in IE 6.0 SP2  saying that "... your security settings do not allow websites to use active X controlls installed in your computer."
Any suggestions?
PS:I have already put unity SA page in trusted sites and enabled all Active X settngs. And in C:\windows\Downloaded Program files  media master ocx isn't there.
Tommer Catlin Mon, 11/23/2009 - 07:53
  • Green, 3000 points or more
Have you tried from a different machine?  Usually the Media master bar
asks for a second login (sometimes, depends).   Turn down the security on IE the lowest possible and try again.  Also make sure your Java works properly on the workstation.
If you can pull it up on the Console (unity server) IE, then its a workstation issue.
etmarcof Mon, 11/23/2009 - 08:56
My problem is in unity server console. From others workstations it works, but costumer want that it also works in unity server console.
I've already turn security settings to low.
Regrads,
MC
