Time/dial-attempt taken to Rotate on multiple dialer strings
Nov 23rd, 2009
I using isdn bri as our backup line. Below is the config on the dialer interface.
If the 1st dialer string is fail to connect, how long is the time/dial-attempt taken before it using the 2nd dialer string to dial?
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 30
dialer string 123456789
dialer string 987654321
dialer load-threshold 1 outbound
dialer watch-group 1
dialer-group 2
no cdp enable
ppp chap hostname xxx
ppp chap password xxx
ppp multilink
end
Giuseppe Larosa Mon, 12/07/2009 - 02:47
  • Hall of Fame,
    Founding Member
Hello Jackie,
I have some doubts that multiple dialer strings are supported in the same interface.
see
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_cfg_peer2peer_ddr_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1006922
you may need to use multiple dialer interfaces that attempt to dial the different numbers.
at IP routing level you can provide preference to a dialer using different admin distances
ip route 10.10.10.0 255.255.255.0 dialer1 10
ip route 10.10.10.0 255.255.255.0 dialer2 20
the time to move from one attempt to the other should be of some seconds
Hope to help
Giuseppe
