Truncate called number using translation rule
Nov 23rd, 2009
I have a Cisco 2851 router and I need to chop off the first digit in the incoming
called number string (e,g 272109 translate to 72109).
I have tried using rule 1 /^.*\(..\)/ /\1/ but I cannot get this to work, keeps saying it is an incomplete command.
Can anyone help please
Brandon Buffin Mon, 11/23/2009 - 08:21
  • Purple, 4500 points or more
Are the numbers always the same length? If so, you can use the following rule to keep the last 5 digits.
voice translation-rule 1
rule 1 /^.*\(.....\)/ /\1/
Hope this helps.
Brandon
paolo bevilacqua Mon, 11/23/2009 - 15:08
  • Hall of Fame,
    Founding Member
rule 1 /^./ //
Remember: what is unmatched, stays unchanged.
