I have a question about cisco ios
Nov 23rd, 2009
my name is choong. i have been studying for ccna. i have a lab with 3 routers and 3 switches. the routers i have are 3640, 2 2610. the switches are 2900 xl series. i redo the ios on one of my 2610. i have 2 rom files when i did the ios how can i get rid of the old ios here is the ver of the router. can anybody help
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 10-Feb-05 02:11 by ssearch
Image text-base: 0x80008098, data-base: 0x80CD32C8
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
Router uptime is 2 hours, 32 minutes
System returned to ROM by reload
System image file is "flash:?"
cisco 2610 (MPC860) processor (revision 0x203) with 28672K/4096K bytes of memory.
Processor board ID JAD050902PT (3217741547)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Configuration register is 0xA102
Giuseppe Larosa Mon, 11/23/2009 - 09:05
  • Hall of Fame,
    Founding Member
Hello Chong,
your system image is flash:?
you can see files in flash with
dir flash:
you can then delete a file with
delete flash:filename
you need then to squeeze to free space
squeeze flash:
I would copy the file again with a more meaningful name, this a quite common error during questions in copy tftp command
Hope to help
Giuseppe
ChinYChoong34 Mon, 11/23/2009 - 18:30
k, i did what u say but the first file does not show when i type dir flash: . is the router suppose to have 2 files?
Reza Sharifi Mon, 11/23/2009 - 19:01
  • Cisco Designated VIP,
    2017 LAN
Choong,
Have you already loaded the IOS version you need? If yes, do a "sh flash all", you should see 2 files, one is your old one that you do not want and one is a new one that you want to keep.  Then follow what Giuseppe posted and you should be fine.
Reza
