Microsoft Virtual PC .1Q 3750 routing issues
Answered Question
Nov 23rd, 2009
Case study: I am seeking help as I am attempting to test the .1Q functionality of Microsoft Virtual PC (only). What I have done is connected a PC w 1gig NIC configured for .1Q tagging and connected it to a Cat 3750 trunk port. I configured 3 VLAN (one per virtual environment) and I created a loopback interface to ping too.
Problem: PING not successful. I am able to see the VLAN tagged on the 3750 and when I show ARP on the 3750 I do see the MAC of the Virtual PC with the correct VLANID but the switch will not route the packet to the LO int. Hence, PING failure. I tried with both no routing and with EIGRP both, to no avail.
Attached is a diagram with info, the IOS is LAN IP not sure version but there are no other config’s on the 3750 it is clean fresh out of the box. I have to use this set as I am limited additional devices due to security policies.
Any suggestions or recommendation would be greatly appreciated. I am leaning towards Microsoft VM the root cause but just not sure. The ping should route and respond.
Correct Answer by Jon Marshall about 7 years 3 months ago
briangrides wrote:
Jon,
Now that I think about it, (we did our testing on Fri) we never did set up the virtual pc's we started with just trying to get the PC itself ping either the vlan (default gateway ip) or the lo int ip. Both to no avail. One question I thought of is I am wondering if there is a issue with facing a trunk port and a NIC interface together, and something getting scrambled in the middle? In most cases one would not interface a trk to a pc it would be an access port. Could this fact be an issue, that you can think of? Microsoft PC is a 2007 application no one really does what I am attempting to do, in this fashion most enterprise environments would use a VMware 4.0 Hypervisor but we have a fire-wire requirement and VMware does not support fire-wire interfaces at this time. Your help is greatly appreciated!
Brian
Had a quick trawl through technet and google and i can't find any mention of virtual PC supporting 802.1q. I can find mention of something called HyperV which seems to be used for server virtualisation and this can support 802.1q tagging.
If your NIC supports 802.1q tagging and for this you need to check the NIC vendor support site then i don't think your issue is with the NIC or the 3750, assuming they have been configured properly but rather with the virtual PC software. It may be worth posting a question on technet to see if they know if virtual PC works with 802.1q tagging.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 11/23/2009 - 10:58
Can you post
1) the config of the 3750
2) the ouput of a "sh interface trunk" from the 3750
Jon
briangrides Mon, 11/23/2009 - 11:47
Jon,
The router is no longer connected to the PC running MVPC. I believe that the sh ip int does will not bar any useful information at this time.
Can you tell me what you are interested in seeing? I should be able to recall the answer? The router is at my desk un connected to anything (this posses the difficulty with me trying to figure this out, poor environment etc..) When the LAN guy has more time I will take the rtr to his desk, but I will not have internet connectivity.
Anything you think of for me to look for, I will and respond back once I able to!
The links was up-up
interface GigabitEthernet1/0/1
switchport mode trunk
run config
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Loopback1
ip address 10.2.1.1 255.255.255.255
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
interface Vlan10
ip address 10.1.1.1 255.255.255.0
interface Vlan20
ip address 10.1.2.1 255.255.255.0
interface Vlan30
ip address 10.1.3.1 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Jon Marshall Mon, 11/23/2009 - 11:55
Brian
I wanted to the config just to give it a quick check over.
The "sh interface trunk" output was so i could see what the switch thought was happening on the trunk link.
One question. You couldn't ping the loopback address on the 3750 but from the PC could you ping each of the vlan interfaces ?
Jon
briangrides Mon, 11/23/2009 - 12:23
Jon,
NOPE, unable to get a ping to the vlan either. Note: we only tried 1 vlan we didnt set up all the virtuals we wanted to make sure we could ping first. The PC was able to successfully ping intself (10.1.1.2) One thing I noticed with sh ip arp (during ping from PC to sw: ping 10.1.1.1) was that the packet entered the switch with the correct vlan10 tag and virtual mac add, BUT, the dest ip adress was 10.1.1.255 (the B-Cast ip) not the ip we pinged: 10.1.1.1
I do not understand this?
Jon Marshall Mon, 11/23/2009 - 12:39
briangrides wrote:
Jon,
Brian
Haven't used vritual PC so not sure how it does things. Just to clarify though, the packet with a destination of 10.1.1.255 you saw, that was definitely the ping packet was it ?
Jon
briangrides Mon, 11/23/2009 - 12:55
Jon,
YES from desktop dos we ping 10.1.1.1 and the arp table showed vlan10 10.1.1.255  The source vlan ip configured on the NIC profile is 10.1.1.2
briangrides Mon, 11/23/2009 - 12:50
Jon,
Correct Answer
Jon Marshall Mon, 11/23/2009 - 13:21
briangrides wrote:
Jon,
Brian
Jon
