11-23-2009 12:35 PM - edited 03-15-2019 08:34 PM
I'm trying to troubleshoot why I'm getting a Busy when dial a my backup line phone number. I have a VOIP telephone system and 2 backup analog lines connected to a FXO port 0 and 1 on a 2651XM router, I'm testing a backup line from my router. So I ran the command csim start 94231294 ...This allows you to determine whether you can properly go offhook from the router to the PSTN, send digits, and complete a call to the destination phone. So typed in my cell phone as the number and successfully received the call. But when i try and call the number back. The number rings Once and then I receive a FAST BUSY. Do anyone have any idea why this would happen? Here's a partial of my router configs.. Thanks in advance!
call rsvp-sync
voice-port 1/0/0
no comfort-noise
connection plar 1999
voice-port 1/0/1
no comfort-noise
voice-port 1/1/0
voice-port 1/1/1
voice-port 50/0/158
voice-port 50/0/159
voice-port 50/0/160
voice-port 50/0/161
voice-port 50/0/162
voice-port 50/0/163
voice-port 50/0/164
voice-port 50/0/165
voice-port 50/0/166
voice-port 50/0/167
voice-port 50/0/168
voice-port 50/0/169
voice-port 50/0/170
voice-port 50/0/171
voice-port 50/0/172
voice-port 50/0/173
voice-port 50/0/174
voice-port 50/0/175
voice-port 50/0/176
voice-port 50/0/177
voice-port 50/0/178
voice-port 50/0/179
voice-port 50/0/180
voice-port 50/0/181
voice-port 50/0/182
voice-port 50/0/183
voice-port 50/0/184
voice-port 50/0/185
voice-port 50/0/186
voice-port 50/0/187
voice-port 50/0/188
voice-port 50/0/189
voice-port 50/0/190
voice-port 50/0/191
voice-port 50/0/192
mgcp profile default
dial-peer cor custom
dial-peer voice 100 pots
destination-pattern 9T
port 1/0/0
dial-peer voice 101 pots
preference 1
port 1/0/1
dial-peer voice 911100 pots
destination-pattern 911
port 1/0/0
prefix 911
dial-peer voice 911101 pots
preference 1
port 1/0/1
prefix 911
dial-peer voice 2000 voip
destination-pattern [1-8]...
session target ipv4:10.1.200.11
no vad
dial-peer voice 2001 voip
preference 1
session target ipv4:10.1.200.10
no vad
dial-peer voice 9000 voip
no vad
dial-peer voice 9001 voip
preference 1
no vad
call-manager-fallback
ip source-address 192.168.96.1 port 2000
max-ephones 48
max-dn 192
Solved! Go to Solution.
11-23-2009 12:46 PM
Is 1999 a valid DN to receive the call? Are your voip dial peers using the correct codec (g.729 by default)? Correct codec configured in CUCM?
Hope this helps.
Brandon
11-23-2009 12:46 PM
Hope this helps.
Brandon
11-23-2009 04:04 PM
Hi Brandon, Thanks for your prompt response. I'm so new to the voice side. Can you explain what is a connection plar 1999 (is 1999 an extension DN (directory number?) and how can I check if is 1999 is capable of receive a call? Would that be in the CUCM?
And what would be the correct codec to use? Thanks so much... I'm also researching the cisco website... I do appreciate your help...
11-23-2009 04:48 PM
Hi Brandon,
Thanks for your help. The problem is resolved now.
02-07-2018 07:05 AM
So what was the fix. I am having the same issue.
