Problems with VPN Passthrough on 2600 Router
Nov 23rd, 2009
We have an SBS server on a test network that accepts VPN connections internally. However, remote users are unable to VPN in through our 2600 Router.
The SBS server is on an internal IP which is NATted on the 2600 to an external IP.
The inbound access-list has been updated to permit VPN traffic to pass through (I think):
permit tcp any host xxx.xxx.xxx.135 eq 1723
permit gre any host xxx.xxx.xxx.135
(I'll lock the VPN source IPs down once I have this worked out)
When you create a VPN connection from a remote Windows client, it appears to find the IP ok, requests the username and password but fails to authenticate and connect. So something isn't getting through?
I can see that IOS contains commands for creating tunnels between fixed locations but I assume that I can ignore these when just creating a simple VPN in to a Windows server?
Any thoughts appreciated.
Keith
Jon Marshall Mon, 11/23/2009 - 16:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Keith
Keith
Have a look at this document which covers how to allow PPTP through an IOS router -
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00800949c0.shtml
Jon
keithglanville Tue, 11/24/2009 - 06:11
Thanks Jon
I am having trouble extracting the bits I need out of this document as our setup is different. For example, there is no cisco at the house end and there are several locations/clients. Also, FastEthernet0/0 has several addresses assigned to it - only one of which is used by the SBS server network - I can't key in anything that might take down the routing or access to/from the other subnets.
The config extract below allows me to get as far as remotely authenticating on the SBS but then nothing.There is only one NAT address setup for the external VPN address 90.4.123.235, so should I also setup PAT to allow multiple VPN clients to connect?
Any assistance is much appreciated.
Keith
version 12.2
service timestamps debug uptime
service timestamps log uptime
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address 10.1.1.200 255.255.255.0 secondary
ip address 192.168.1.200 255.255.0.0 secondary
ip address 90.4.123.254 255.255.255.0
ip nat inside
speed auto
full-duplex
interface Serial0/0
description Connection to Line
ip address 92.253.158.54 255.255.255.252
ip broadcast-address 92.253.158.55
ip access-group inboundfilter in
ip access-group outboundfilter2 out
ip nat outside
encapsulation ppp
no fair-queue
router igrp 1
redistribute connected
network 92.0.0.0
network 90.0.0.0
ip nat inside source static 192.168.1.10 90.4.123.235
ip access-list extended inboundfilter
permit tcp any host 90.4.123.235 eq 1723
permit gre any host 90.4.123.235
ip access-list extended outboundfilter2
permit udp any any
permit tcp any any
permit gre any any
