Need help with TCL script to play audio file and then transfer call
Nov 23rd, 2009
FXO-TCL-VoIP Dial peer to CUCM 7.1-Hunt group to ring all phones at remote location
everything works up until it rings the hunt group.
it then drops, playing the recording that says the number is not available. i would have thought the script should be out of the call once it gets sent to CUCM..
any help would be greatly appreciated.
paolo bevilacqua Tue, 11/24/2009 - 02:42
  • Hall of Fame,
    Founding Member
No, the script is still in control of the call untill the first transfer succeds.
Your script simply does not contain the logic to support transfers.
If you weant to acquire a script that correctly support transfer and more, contact me at the address present in my profile.
Related Content
