I have a question about Error message on the WS-X6248-RJ-45
Nov 23rd, 2009
Hi, there
What does it mean by below Err Msg ?
and  What is the Bus Asic ?
Do you happend to have the architecture of WS-X6248-RJ-45 ?
ㅁ Verson     : cat6000-sup2.6-4-13.bin
ㅁ supervisor : WS-X6K-SUP2-2GE
ㅁ Chassis    : C6509
ㅁ Err Msg   : %SYS-3-SYS_LCPERR3:Module 9: Bus Asic #0 out of sync error: Module requires attention - troubleshoot or contact TAC for assista.
Laurent Aubert Mon, 11/23/2009 - 20:09
  • Cisco Employee,
The bus ASIC is used to send packets for lookup. The port ASIC handles transmission and reception for several physical interfaces.
Please try one of the following workaround and if it doesn't make the message disappear, open an SR for RMA request:
1- Try to reset the LC
2- Try to reseat the LC
Laurent.
Kwangwon Seok Mon, 11/23/2009 - 20:35
Hi, Laurent Aubert
Is Port ASIC the Pinnacle ASIC or Coil ASIC ?
Kwangwon Seok Tue, 11/24/2009 - 16:52
Hi, Laurent.
I appreciate your help.
By the way,
There are 4 Coil Asics on the WS-X6248-RJ-45.
If Port Asic is Coil Asic, a group of ports should not work.
However, All the user who connect to the ws-x6248-rj-45 didn't work.
Laurent Aubert Tue, 11/24/2009 - 17:34
  • Cisco Employee,
The issue is on the bus ASIC shared by all Port ASIC's.
Laurent.
Leo Laohoo Mon, 11/23/2009 - 20:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
This error means that you need to contact Cisco TAC and organize for the blade in slot 9 to be RMA-ed.
ASIC stands for Applications Specific Integrated Circuit.
