why delay can't work???????
Answered Question
Nov 23rd, 2009
i have two router and one switch,all of then connect to the switch.now,when i change the r1 fas0/0 's delay 10000.and ping the ip
of r1's fas0/0 by the r2.the response time is only 23ms.why? i have change the delay is 10000.
Correct Answer by Giuseppe Larosa about 7 years 6 months ago
there are software based WAN emulators I've used some years ago one from Shunra to emulate a satellite link
http://www.shunra.com/shunra-ve-desktop.php?keyword=Shunra%20VE%20Desktop
you can download a free trial.
it should allow you to emulate delay, packet loss and so on.
You should install it on a PC with two NICs.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 11/23/2009 - 23:20
  • Hall of Fame,
    Founding Member
delay and bandwidth are administrative parameters that are used by routing protocols like EIGRP to calculate metric.
bandwidth provides a reference for modular QoS.
you cannot emulate a high latency link using the delay command, it has no effect on how traffic is processed.
be also aware that delay is set in tens of microseconds so 10000 is actually 100000 microseconds = 100 msecs
Hope to help
Giuseppe
QFX527518 Mon, 11/23/2009 - 23:32
very thx giuslar. i know the delay and bandwidth are administrative parameters .other ,how can we do to dealy the traffic on fastether ?
Correct Answer
Giuseppe Larosa Mon, 11/23/2009 - 23:38
  • Hall of Fame,
    Founding Member
Hope to help
Giuseppe
